new to the forum and 7.3 psd
cherokee97
woodstock ga
hey guys! i just bough an 01 f250 ccsb 4x4 4r100 lariat 7.3 truck. this truck is a big upgrade in every aspect from 1990 RCLB f250 with the 7.3 idi except for the fact that it seems to drink fuel like no tmmrw.... i average 13 mpg in the city and 16.5 on the highway. my idi didnt care how it was being driven and it averaged 16-18 mpg. the truck does have 277k on the clock but has been decently maintained. things i have checked are as follows. the turbo, cac piping and cac, cps just replaced due to the recall and i did change oil and fuel filter, inspected air filter and air filter box, no fuel leaks, minor exhaust leak before the turbo, tires and alignment are in good shape, i dont drive like a madman either. the engine does not smoke at all. i run additives every tank. are there any sensors or exhaust pressure tubes that need to be looked at? also it has 3.73 gears and i have the hubs unlocked. what are some upgrades that i can do for under 1000 dollars to improve fuel economy including a chip, exhaust and intake? im not looking for alot of power increase mainly fuel economy. thanks for the help!
Welcome to SDD.com, glad to have you here and hope you enjoy your new to you truck. You live near a man that can help you with your truck.
His name is Bill and his shop is Power Hungry Performance. Should be able to Bing.com and find it and get his phone number. It may also be called PHP.
clintusaf
Clint
Bossier City
Welcome!
How are you calculating your mpg?
As far as things you can do maintenance wise, I would clean out your EPBS tube.
https://www.youtube.com/watch?v=XLZI2wMpn5I
http://www.guzzle7pt3.com/ebps.php
As far as upgrades, you mentioned the top three, my suggestions four you budget would be:
6637 air filter-http://www.riffraffdiesel.com/riffraff-diesel-6637-filter-kit/-$90
MBRP 4 inch exhaust-http://www.riffraffdiesel.com/mbrp-4-aluminized-turbo-back-1/-$310
DP tuner/TS 6 posistion chip/ PHP's hydra chip-$400-$500 depending on tunes
I would also suggest a set of gauges to monitor temps, especially after adding power adders.
Hope this helps!
