New Turbo Problems, Part Deaux
no-red 6 0
Senioritis
southmetro MN
yeah, i could pretty much back up 'got diesel'. just to add, i believe the changes are in model year. each one got a more vaned turbo. i read it too.
and nothing beats my:woot :woot whistle...
well, the new turbo is bein installed right now as i type, so we shall see how it does on the drive back to henager, to return the turbo i bought there.
BTW, my new banks air filter intake system should be in today by UPS, cant wait to get it on.
i will be sure to take some pics of the install to share with everyone.
:thanks for all the help ya'll have been.
do i say "ya'll" too much? :dunno :roflmao :roflmao :roflmao
another update.
the tech workin on my truck just 2-way'd me and told me that he had everything put back together, cranked it up, and it has an exhaust leak at the Y-pipe that connects to the turbo.
he did say that when he was putting the turbo in, he must have bumped it and it broke, BUT, he does have another Y-pipe, and there will be no cost to me for it.
SO, maybe i will have my truck by late this evening or tomorrow.
HUMMM...well that would certainly reduce the spin up of the turbine...since
its on the PRE turbo side...
bush, the y-pipe wasn't broken when this second turbo came out. it got broken when he was puttin the ford turbo back in.
the Y-pipe broke in the flex area.
bush, the y-pipe wasn't broken when this second turbo came out. it got broken when he was puttin the ford turbo back in. the Y-pipe broke in the flex area.
understood...and this is a common area for cracks too, so im not
a bit surprised that it broke...good on 'em for admitting he did it
& that its not gonna cost you.
well, i have more bad news. turns out, it actually was not the Y-pipe, it was the elite diesel up pipe that i had bought that broke around the flex area.
called up elite diesel and told them that their part failed, so i will be sending it back to them for a full refund and the S&H too.
good thing i saved the original OEM up-pipe, cause it will be going back on tomorrow. i am gonna try and see if i can get the scoop out, so not as much hot exhaust air will be goin thru the EGR cooler.
trail and error i guess. all this crap sure is a pain in the but.
and i am sure there will be some of you that will give me the old saying of
i told you so" thats ok if you do, let me have it.
roosterdiesel
Earl needs B100
Amarillo,TX
WOW!:sorry
What did Elite say about their pipe failing? Could you take pics of it before sending it off? I'd like to see exactly what failed, just curious.
:sorry about all the probs, hopefully everything will go better with this turbo.
and you probably EXPECT ME to be the one that says it...
I feel for ya...just want your truck to run & run right...sorry
youre having to even MESS w/ it, much less go thru the pain
and suffering of being w/out or doin' the testing/trial & error.
we'll all learn from youre testing just the same...nothing ventured
nothing gained ! hang in there !
thanks bush, and yes i knew you would chime in. :roflmao :roflmao :roflmao
