Help Needed No Lube in Rear End!
hotrodturbo7
nowhere, mt
HAHA yeah thats what she said, very funny...
My rear differential failed on my 2001 f-250 lariat, it is the s409h 3.73 limited slip.
What other years/axle codes could I bolt right in to get the truck back on the road?
appreciate any help you can offer.
BTW first post, awesome forum here
platinum01
Willis, TX
Wow sorry to hear that. Welcome to SDD.com. Is there a leak some were or did it just disappear?
bigrigr
Real trks hv 3 pdls
provo, utah
I'm not real familiar with the codes, but I think all 99 up psd's have the sterling axles. obs trucks came with dana's i believe, but not positive. Just use a tape measure on the axle perches,and remember, the wheel bolt pattern on the obs's is just a bit different as well. still 8 lug, but not the same spacing. Hope this helps, and good luck. Welcome to the site!
use Car-Part.com--Used Auto Parts Market as a good reference for what will interchange. It will give you a list of years that they have parts available from that will fit the application that you provided.
From what I can tell it will be '00 - '04 and it appears you have a limited slip axle.
Frankenstien
Frankestien
South Prairie Wa.
... The dually's are Different... Dana 80's the SRW are Sterling, as mentioned you'll be best served to stay with your year model as lug sizes changed.
