No throttle peddle response
Hooper
Hemet, Calif.
This morning I started my truck, let it warm for a 3-4 minutes, got in to go but had not throttle response. It was idling normally, but when I put it in reverse and applied throttle, it just continued to idle. After pumping the throttle a few times it picked it up and away I went. Seem to recall it doing this before but its been awhile. Any ideas? Pedal position sensor??
Tbar
SDD STAFF/Moderator
TPS - Throttle Position Sensor
Tbar
CKyle494
Maryville, TN
Or you can check out the part here. Should be same thing just a little cheaper. Just search for the same thing. Sorry about that Dave, I'm probably the cheapest SOB around and would find it cheaper by the Penny I would go for it.
DragonSlayer
Pensacola FL
^^^^^^^^^^^^^I agree with the posts above....TPS.....seen it a thousand times....this makes it 1001!!
ebbnflow
NORCAL
I'm having a similar problem. I have no throttle response, a blown fuse #45, no working gauges or odometer and the overdrive button does not work. I replaced the fuse and it came back to life, but then this morning it had all of the above symptoms minus the blown fuse. After tapping the petal a few times, it all came back. Your thoughts and comments will be appreciated.
