Help Needed not charging, no dash except for battery and abs light
03superduty
Syracuse, Ny
Ok so battery light came on, checked the voltage was down to 12.69 running, swapped out the alternator voltage jumped to 13.5, a week later its down to 11.4 and my dash cut out, the windows dont work, fan only blows on low and the battery, abs, and air bag lights are on. bad alternator? bad battery?
check the connectors on the alternator for splayed connectors and heat damage
wiggle them and make sure you don't have one broken inside the insulation
take the batteries out and have them charged and tested.
Changed the plug on the alternator and put 2 brand new batteries in. Sits at 11.89 volts at idle.
I'm think'n it's time for >2< new Batteries.. then check the Voltage out-put. If it's still less than 14v..the Alternator has gone south.
Was the "swapped out" Alternator New ?
IHC Power
STOCK STROKE
Walpole Mass
Charging issue
Do yourself a favor and pull the alternator to have it tested first before you exchange it. Make sure it's on the machine correctly like wired in your truck. If it tests good and the batteries are new, all connectors are ok then you should check all the fuses then get a wiring diagram and locate the fusible links. Check and replace if necassary. I just fixed my buddies gas job f250 yesterday. He ended up replacing everything for a bad fusible link. Dont over complicate it, you need dc voltage in to create the ac voltage, then it gets rectified back into dc for the trucks use. Good luck and keep trucking.
