PML differential covers
Mark Craig
Advertising Sponsor
Franklin, Tn
Crumm,
The PML's are great products, we have been selling them for a couple of years now with 100% customer satisfaction. They get you the normal items like a magnetic drain plug, and a port to add a temp sender too. Plus they increase the capacity of the fluid as well as help cool the fluid too. They are clear anodized vs powder coating as powder coating is a great insulator and can actually contain the fluid heat as much as the use of cast aluminum helps reduce it. If you guys have any questions just call us at the office.
Mark @ DPPI
Isn't there also a option without the port? In my climate there is no worry about overheating the rear-end. I doubt I could ever build enough heat to get a temp guage off the peg.
Wood County Tx
95_stroker said:
Amazing what 40K will get ya these days isnt it. :D
what you talkin bout "Willis"
39,999.00 :D
it is a nice cover for them 4.30's been lookin greal hard at it to put in a temp probe. cant imagine how hot it gets at 75 pulling the rv, dont even want to geuss
I cant believe that something as elementary as fins on a diffy cover (or trans pan for the matter) hasnt been standard for years already.
You think they are just now going to the cooling fins due to the higher output of the engines which in turn creates more gear oil heat?
