Dragon
OK... I pulled the passenger side hub. Looks good, no visible or mechanical wear or looseness. I plan on cleaning it up, packing the needle bearing and re-installing it. The rotor flange is indeed 13 MM on this side (passenger) also. The vacuum o-ring is there, but...the thrust washer was put in backwards (by the factory or dealer) and it is cracked in half ! ARGH!
