boatin said:ok , I put a scanner on it and first code I got was
P0237 Turbocharger Boost Sensor A Circuit Low
then did a injector buzz test and got
P0273 Cylinder 5 Injector Circuit Low
the oil does have a burnt smell to it
BJS said:I'm going with the masses w/ the inector wiring harness usually it's a result of a bad glowplug that has damaged the harness. there is also the possibility that it's an internal problem but unlikely since you said that you could smell burnt smell to the oil.
Thank guys , Just chesked the injector harness and cyl#5 was burnt. all the others looked good![]()
