BLUKTY
Okay, I give up!! -mad I am in the process of changing my transfer case, front differential and rear differential lube to Amsoil lubricants. I was able to change the transfer case and front differential without a problem, but I cannot find the proper tool to remove the rear differential fill plug. It sure looks like a torx bolt, but a torx 50 is too small and a torx 55 is too big!!! Do any of you Powerstroke guru's know what size torx this plug is?? Or is it not a torx at all, but something entirely different ????? Thanks in advance for any help, I had no idea that this would be such a complicated process ! Pete
