Question Replacement Turbo
Doghead
Cobblehill, BC
Well I performed the on truck compressor wheel swap and had some issues with the procedure. I put a screw driver in the turbine side to hold it while I attempted to loosen the compressor wheel and things just didn't feel right so after repositioning several times and not being 100% happy I got a mirror and looked at the turbine wheel. I bent a fan blade on the turbine. I finished the install and through it back on the truck. Now I want to replace the Turbo because I am affraid of the impending destruction of my current one. I have been looking at the PDR super GTP ($1485 from Piers in Canada http://http://www.pdrdiesel.com/catalog/Turbochargers-167-1.html) this is about all I have to spend. I would like to know if any one has any comments or suggestions on this turbo or another similarly priced Turbo? I do some towing but not alot and I have the gauges already. So I just need some help in deciding which way to go.
treyloco
Metairie/Louisiana
The PDR is a good turbo from what i have heard but there still isn't alot of people running them for me to feel confident. Personally I would save a little more and get the Garrett BB turbo, it has been around awhile and has proven it's self over and over.
mrwrench
Urbana IL
xtremediesel.com has the wicked turbine $59.99
maybe they have the exhaust wheel that you probably need.
is the exhaust side wheel damaged?
mrwrench
Urbana IL
other option:itpdiesel.com
complete rebuilt kit , shaft bearing and wheels by 295
Doghead
Cobblehill, BC
Yeah It the exhaust side thats damaged there doesn't seem to be any one in BC willing to sell just the exhaust side turbine wheel. They all want to rebuild the Turbo for $700 to $900. It is cheaper than the PDR Turbo but I have the opportunity to upgrade my Turbo.
PStroked444
FL-Leesburge
Check out Rons Turbo Shop. PH# 801-842-9186. Outstanding guy. The exhaust wheel is part of the shaft. If you want to rebuild it yourself it is easy. He can rebuild it for you. The exhaust wheel costs (memorie correct) 120.00. Give him a call. Good luck....;tu
Doghead
Cobblehill, BC
I Ordered up the PDR should be here before next weekend. It made for an expensive compressor wheel swap but should be good fun.:burnit
