Search for improved trans with better MPG 7.3L
Ken1
Mississippi
Just atarting to research if any later model trans or improved engineering will help to improve our MPG
Has anybody here mated up a GV to a 4R100 yet or can it be done? I know the IDI guys are crazy about the GV's but.... for the most part they are dealing with 3 spd trannys or bolt actions.
at about 3k plus install the GV boxes STILL make it a tough
ROI.
even gear vendors doesnt show it an a compatible option
for the 5r110 & 4x4
you could do a 3.55 (and still tow) for 1000 bucks or so...
but again, reportedly, youd only gain 2 or 3 mpg (on the highway).
a 3.08 would net you an estimated aditional (interstate) 5-6mpg
but your towing would suffer such that id expect you wouldnt WANT
to tow...on the interstate SURE youd be happy (long hauling)....but
its a bit of a trade off @ best.
ROI.
for the 5r110 & 4x4
the other thing you have to control is your slippage... and your biggest source is the torque convertor itself... I'd call a trans shop that specializes in deisel towing trannys like BTS because even after 30 years in the business, I still farm my trans work out..
OPPS... i see this is in the 7.3 forum...sorry
the GV is available for the 4r100...but the pricing issues
are the same ($2895-$2995) plus install ($650-750).
One of the weak points of the 4r100 is the converter...
and BTS has made a good business in repairing and
"beef-ing up" the 4r100.
3700 bucks buys ALOT of fuel (1000+ gallons at 3.50 per gallon)....
nearly 40 tanks for fuel (in my truck)...
Ken I know this is off the original topic but have you done any improvements such as Intake,Exhaust system,Fuel Pressure bumping and any of the low cost/freebies available for our 7.3L's that do aid MPG?
I also endorse Brians Truck Shop as our 02 Excursion will be heading there for a new trans.
keanoknick
Big Stroker
Cowtown TEXAS
for the 5r110 & 4x4
A bit off topic, but GV does make one for the 5R110 & 4x4 a guy I know locally has one on his 04, I think he might be signed up on this forum as hpprose but doesn't post very often.
