SHAKE, RATTLE AND ROLL
COMPOSER
COMPOSER
Lakewood, CA
On decelleration, starting about 16mph down to 10 mph, I get a strong vibration like I am going over the lane bumps on the freeway. I have this regardless of what gear I am in. The brakes do not start this I can be costing and it starts. Any ideas?
Hoss 350
My GSP, Dutch
Spokane, WA
What sort of tires are you running? Any noise or just vibration? Where do you feel the vibration, steering wheel, seat of your pants, feet?
COMPOSER
COMPOSER
Lakewood, CA
It just started. tires are 4k old. I feel it in the front end. It is not a side to side feel, it feels up and down like the front end is going over freeway lane bumps.
fordtrucker4life!
I work with waste
SE Michigan
does it vibrate above those speeds? Did you get the tires balenced when yiu got them? what size and type are the tires? we need some details
Yellowsub1962
supernewbie
Ventura County
sounds more like a blown shock. If it was a brake shoe, the steering wheel would likely shake bake and forth with the "grabbing" of hte shoe.
Also check ALL you suspension components for slop. Jack up the front end and give the everything a shake. Check for loose bearing, bad locking hub, loose lug nuts, tie rod ends, ball joints, shock bushings, etc. If you don't find anything I would stat be haveing the tires checked out and rebalanced (hopefully you bought them from a place that has lifetime balance to sacve money). It might be something as simple as you lost a wheel weight.
COMPOSER
COMPOSER
Lakewood, CA
I will have the tire shop rebalance and check the front end completely for any slop or worn parts.
Thanks, you guys that reply are great!
