roosterdiesel
Earl needs B100
Well I got the system installed, started with the Evo uploaded. Tried the new chip with DP Tuner HPOP tunes, no start.
WTS light never goes off. Pull the chip and it starts stock. I haven't run a chip in a few months. Maybe need to touch up the contacts with some solder.
It seemed a little loose. Didn't try the DI chip.
Uploaded the Extreme program from the Evo and took it out for a hard drive to get the air out. Seems like a little more low and midrange, NO smoke once the on top of the turbo.
Use to have a pretty good haze before.
Now for the bad part...pulled over to fill drinking water jugs. Looked under the truck and it's leaking oil. Good trickle at first, after water was filled it was just dripping. Got home and it's trickling again and theres a slick under the truck. I can't see where it's coming from and everything's too hot to look too hard.
Here's what the undercarriage looks like after about a 10 minute drive...
