Still having White Smoke
StrokinHarley
GA
So after the EGR bug hit i thought i had things solved and all was good for a few days but now the white smokes coming back. could it be more EGR problems?maybe i didnt clean it good enoug? and another thing my truck just seems like it doesnt stay warmed up anymore like when i first got it u could come and crank it after 5or6 hrs of sitting and the gauges would read about normal for a warmed up engine but now if its parked for more than an hour its back on dead cold:dunno
no-red 6 0
Senioritis
southmetro MN
iirc; didn't you just clean your egr awhile ago? i assume u did it correctly and did not get any cleaning agent or sooty crud into a certain few holes!?!?
the wihite smoke seems to be a tell tale sign of perhaps larger issues ie: head gasket troubles, egr, egr cooler, injector(s). best bet would be to take it to the doctor and have it checked out. get them to do a compression check and check for coolant loss.
good luck and keep us informed
StrokinHarley
GA
yea i think ill do that soon but i gotta slide that kitty back in real quick:sly
StrokinHarley
GA
i went back and pulled the EGR again and discover a gash in the o-ring so i replaced them, but now it blows white smoke only if im idleing or if i let off the gas pedal fast any ideas. im trying to stay away from the dealer so thats not an option at the moment:dunno
no-red 6 0
Senioritis
southmetro MN
i am thinking exercising that 'option' is your only option....don't want to ruin anything else and make it worse...
fwiw & jmo
StrokinHarley
GA
well i went to crank it this moring and noticed oil comin out the exhaust pipe so big blues headin to the stealership wednesday maybe it wont be to much:doh:
StrokinHarley
GA
Well guys after a new EGR, EGR cooler, turbo and all new fluids ford seems to have finally got big blue up and running like a top. I tell you what i really did miss her while she was at the ford place for 7 days:D
no-red 6 0
Senioritis
southmetro MN
strokin-
yep, that is the common theme (cause/effect - issues)
that is what i thought would be the case as it was the same w/ mine but a little more extensive..
glad its back and runs like a top.
