stripped spline?
wade145
Illinois
I have a 2000 250 and under heavy throttle it slips sounds like an input output shaft or drive shaft. would it still drive if any of these were to slip a spline shaft? the rear drive shaft is sloppy but i wouldn't think it would still drive after slipping the splines.
WELCOME aboard SDD !!!
How many miles on yer 2K ?
Drop, Inspect and lube the Slip shaft, and check it's carrier bearing for any play. U-joints too.... but this sounds more like a tranny, or rear-end issue to me.. off the top..
wade145
Illinois
i'm taking the drive shaft in to have a new joint welded in it. the diffs are full. I just changed tranny fluid and filter it wasn't burn or brown but the filter looked nasty when I dumped it out.
wade145
Illinois
Also the carrier bearing is shot waiting to replace it till after the shaft is done hoping two days or so.
;tu
Sounds like you've Nailed it.
Let us know how it turns out for ya ?
WOW ! 134K ain't much.. for a 2K. Lots left in it for ya.
Milly333
