Suspension for 2004 PS
jcabe1
Franklin, NC
I have a 2004 250PS, but when I hook my 2006 Flagstaff TT the rear drops about 6 inches. Are there any shocks that would prevent it from dropping? or is it a springs problem.
Thanks Jack Cabe:confused:
You have a spring problem. The shocks don't hold up the truck, the springs do. The shocks just dampen out the up and down motions. Now you can add some air bags (Firestone) to carry the extra load if you want to.
Norcal250
Gimp member
Castro Valley, CA
I second that... AIRLIFT makes a good kit also
Northeast Texas
Q.
What is the weight of the TT
WHat is its length?
What is your tongue WT?
Do you have an equalizer hitch?
Is your 250 a shorty or long bed
Do you have a lift installed
DId it replace the springs
If your dropping 6 inches, your tongue WT is pretty high, we need to establish the loads first then the resolutions,
like spring bars, WT distributing hitch, or air bags, etc, your max trailer on a bumper is 12,500 as per ford.
we need more info
F350DRW1
Waylon Fan
N.J.
I use a simple set of Timbrens on mine, and they work well. Cheap, to boot.
Northeast Texas
I think we are missing the point.
yes bag or timbren will help bring the rear back up.
BUT
if its dropping 6", his Tongue wt is heavy probably near 1200 lbs. or over.
if it is he needs to use a wt dist hitch and spring bars to be SAFELY hooked up and keep equal traction on the stear axle.
TT need to be LEVEL and with proper tg wt and axle wt to ensure it tows with out fishtailing or bumper wagging. and an even load ditributed on each trailer axle.
Air bags and Timbren rubber buggy bumpers do not increase GAWR or tow rating or GCVWR, they only help to limmit the amount of squat. or reduce spring deflection under load and while moving.
-popcorn
