Suspension popping??
patrickc
Ontario, Canada
There is no need to upgrade to an aftermarket trac bar providing nothing is wrong with stock one. The only reason did is because after lifting my truck 9 or 10 inches the stock one was not long enough.
I am not sure on the spring bushings my lift springs have poly bushings in them. I know skyjacker, procomp and superlift all sell bushing kits but I'm not sure if they fit stock springs.
bonestroker
stroke it if you got it
In the field
Try and change out the palsket in between the leaf springs i think there called saddles but I don't know. Mine was going the same thing and that fixed it. hope this helps
patrickc
Ontario, Canada
Energy suspension makes replacement polyurethane bushings for stock 99-04 superduty springs. Energysuspension.com
