The '08 F450 takes up a lot of room
Just wanted to share some pics of a new 2008 F450 we just delivered down in Jacksonville, FL.
It's headed over seas on a big boat.
what kind of rear diff. is that? welded on cover and all....:eek::dunno
must drop in from the front...like the, dare i say....TOYOTAS....
nice if it does cause then you can build it on the bench, set the
backlash and THEN drop it into the case.
notice the square (stronger) axle tubes :sly
Have you ever looked under a big truck? Rockwell's and Eaton's drop in the front and have square tubes. A F450 is a heavy duty truck with a heavy duty axle. Toyota - :rolleyes:
nice truck. Crumm, what do you want one of them for, Crummy is almost new!!
I said "someday" like when Crummy is wore out.
Can you tell where it was going to?
To the land of deserts and camels
