Digital Oxygen
Got Boost?
Yesterday, I decided to take my Hitchhiker to Colorado and store it at a friend of mine's place for the winter. The camper is 34.5', and it tips the scales at around 12.9K with all the junk in it. For the trip, I decided to plug my LiveLink software I use for my Hot Rod, just to see what engine parameters I can monitor... and to make sure the aftermarket water gauge was close to what the computer was seeing. - When I installed it a few years ago, some guy on a forum told me installing the temp probe in the cyl head would give me grossly inaccurate results, blah blah blah. -
Computer and aftermarket temp readings are FOUR degrees off! Aftermarket gauge shows 194℉ and the computer sees 190℉ (as generally seen during normal driving). That is not a gross inaccuracy, IMHO.
But what caught my eye was the following:
When water temps are low (190'ish), oil temps are higher than when water temps are high. See screenshots.
This leads to the question "Is the oil cooler on the Power Strokes so efficient that when moving down the highway pulling a heavy load under high rpm (2500-3000) it cools the oil with such efficiency it's scary, or (the more plausible explanation) Is the PCM on crack?"
