This is going to be nice?
f100cleveland
When In Doubt,THROTTLE ON
Southern Minnesota
So for us guys in the north country what happens when it freezes? From what I have read the solution freezes at 11 degrees. Makes it useless for 3 to four months up here.
dpantazis
#12
under the cheddar curtain
the DEF Exhaust cocktail which contained ammonia gets REACTED by the catalyst to become NITROGEN and WATER. Consider that the atmosphere is 78% nitrogen gas already.
here is a decent read on the system and its components-
http://www.cumminsfiltration.com/pdfs/product_lit/americas_brochures/MB10033.pdf
yes, the DEF can freeze at 11F. and diesel clouds at 40F and will be gelled if you don't protect it. these engines are designed to be started at these temperatures and already have fuel heaters and the like. the DEF systems probably already take that into account.
The MB Bluetec system was the first commercial one. It works fine and the owners of those cars are happy with the system.
i don't think that this is going to get worked around. its WAY too complicated a system.
<soab box on>
the thing that gets me is that you diesel only truck only guys bitch and moan when the diesel car guys are dealing with stuff 3-5 years ahead of you. open you minds and accept the future. deal with it. sitting around and complaining about it makes us look stupid. VW had an EGR system in 1999, 5 years before any trucks did. we dealt with it. instead of disabling it, we figured out how to live with it.
all the guys who do the CCV mod that essentially dumps the oil into the air and on the road say how great it is. but would dump motor oil into the drain or on the ground where your kids play?
<soap box off>
so we become the feeder of machines, they will need our bodies for thier own survival,
sound like any movies we have seen over the last 12 years?????????
"honey... this ATM machine just called me an *****hole!!!"
<soab box on>
<soap box off>
"listen to Obi-wan you shall, hmmmmm?"
Wondering what will happen to the systems if you run B100 juice in the truck and mix it with the pee juice. Do you get asid rain from the tailpipe???? :dizzy
I do see the exhaust business getting alot of new work.
mygsris2slo4u
Erial/NJ
<soab box on>
<soap box off>
If you're worried about oil and ccv vapors being around your children then I would keep them off of the local school bus. International in particular used an open atmosphere ccv on busses up until recently. :eek:
As I stated earlier; this system which will disable the truck in some way will probably be figured out before the first truck leaves a show room. It seems that all they have are sensors to monitor perameters of the system which can easily be fooled or overridden.
