tranny cooler
chaddiesel
Kerrville/Texas
I was wanting to upgrade the transmission cooler and noticed that the lines go into the radiator :cool: . Would it be best to add a cooler to the return line and mount it in front of the radiator, or what other options can you do?
My personal preference is a solo fluid line pair to the cooler from the transmission rather than running thru the radiator.
Indeed mount the new cooler in front of the AC condensor for maximum airflow :sweet
Bill
There are two schools of thought on the coolers. One is to use the rad and the cooler. This allows the tranny to heat up a bit quicker when it is cold. It also keeps the fluid from reaching very high temperatures. The second is to dump the rad and just use the cooler. I think I would choose the first one, but it is your choice. Good luck.
probear
Whoresetmytitle?
Gainesville/Cumming, GA
I stayed with the initial design of my 99, which has a separate cooler in front of the radiator. I did replace the stock one with one from a V-10 automatic as it is 50% bigger than the stock cooler, and bolts right in. You will have to bend the supply/return lines a little, but it still looks factory.
Any photos of that available probear?
Bill :thanks
DmaxEter
I bet its like mine and has both radiator and air-to-oil coolers on it already. Just replace the factory Air-To-Oil cooler with a V10 unit.
BK Meyers
cooler...
Do you have a part # for the V10 cooler???
Thanks,
BK Meyers
Thanks,
BK Meyers
1999-2000 V10's used # XC3Z-7A095-CA
2001-2003 V10's used # 3C3Z-7A095-AA
Bill :cowboy:
dserge66
