JOAT
I Found Nemo!
Got on it hard coming out of the toll plaza, and either during 1-2 or 2-3, it felt like it shifted up then dropped back a gear, hard.
Since then;
-shifts feel late, except TCC at 30 instead of 45
-runs at higher RPM in each gear
-several hundred RPM higher in OD (2700 rpm at 60mph instead of 1800ish)
-NO reverse (found that out in a bad spot)
All shifts occur, OD off works. Like maybe it lost a planetary engagement somewhere? Over running clutch? solenoid or valve body????
Will study some on it before I pull the tranny, but thought maybe some of you tranny gurus would know right of what section quit on me...
Since then;
