Trans problem
Buffs F-350
New Jersey U.S.A
Ok guys I need some help. On my way to work today and I got on it a little to pass some slow traffic the tow/haul light starts flashing the display says cheak guages and the trans temp guage is on zero. So I stop and pull out my evolution and pull a code P0713 I pulled all the power out to stock and the light was still on and the CEL. I eased it to work and when I got out I pulled the same code and I cleared it again. Truck seemed to drive fine half way home temp went to 0 and tow/haul flashing again but no CEL. It runs and shifts fine so any thoughts.
System Grouping: Transmission
Transmisssion Fluid Temperature Sensor Circuit HIGH Input
certainly your temp isnt high, rather sounds like code is being
thrown because you temp sender is bad...in the torqshift/5r110
the sender is inside and part of a wiring harness (pan has to be
dropped & the internal filter should be changed when you drop
the pan)
