"Trouble Light"
J L Dunn
J L Dunn
Kingwood, tx
Yesterday the ABS trouble light came on...what does it mean?
'99 F250 7.3L
I'll hang up and listen :)
JLD
atk
Moderator
simcoe, ontario, canada
'99 F250 7.3L
JLD
it means there is a problem with the anti-lock brake system....it could be simple as the sensor on the rear diff as previos stated...if you can get a code reader and see what the code is, that should pretty much pin-point the problem....hope this helps
sagebel
Stock? Pfft!
Albuquerque, NM
Other symptoms of the speed sensor are odd shifting and no cruise control or cruise control that seems to hunt for the set speed. If you do decide to replace it, it is sometimes refered to as the "rear axle abs sensor" don't ask me why.
