Turbo Timer
rum4by5
Member
SC
Anyone using a Turbo Timer on their diesel? If so let us all know where you got it and the brand you are using. Is it worth the effort to install one?
I dont have one but I wish I did. IHMO, I think they are well worth the money and effort.
Weweld
Fillmore Ca.
We use the Turbo Temp Monitor by Isspro on all 3 trucks.
Instead of time it goes by exhaust temp , when it cools to 325-350 it shuts done then.
One of the better upgrades you can do for your truck
GENE
Wood County Tx
I run mine through my alram with remote start. it runs for 5 minutes, and can be set to run for 30 if we pull into a rest area.
Robert
KansasDiesel
fly'n low on WVO
Kansas City area
GENE
I was also look for a turbo timer that stops with temp instead of time who carries this and how much should we expect to pay.
:cowboy:
rum4by5
Member
SC
Thanks for the info guys. One more question where did you place the thermocoupler for the timer? (post or pre turbo?)
Fire1 installed the thermocoupler pre turbo drivers side exhaust manifold on our truck :sweet
Fire1
Certified Diesel Driver
Deffinately PRE turbo. Like CHP said, driverside manifold just prior to the up-pipe. Pretty easy to drill and tap. Take your time. :sweet
