Vacuum reservoir
82FordTruck
My truck has a vacuum over hydraulic actuator on it. It uses the stock system, and adds two hoses about 3/4" in diameter that go all the way to the back of the truck. I have no issues with this normally, but when pumping the brakes in bad weather I get a little spooked. I have begun using the clutch to downshift, keeping RPM's up, but have also considered putting in a large reservoir, effectively doubling or tripling the length of time I have before getting a hard pedal. Does anyone know of any item that will fit this bill, in a 3-5 gallon size? I am considering a air bubble tank mounted on the frame rail.
I do know that my vacuum pump is healthy, and that my rear brakes are well adjusted. I can manually activate the trailer brakes and see that this is the large draw that has been workign on my system. I do have a guage and warning light built in with this system, and can monitor my vacuum level.
I suppose my other option is a hydroboost conversion.
Any ideas on this?
Do you have an old BBQ propane tank around? You might be able to plumb one of those in or if not that then how about a portable air tank?
dserge66
