Humor van turbo
bigrigr
Real trks hv 3 pdls
provo, utah
What's the deal with van turbos? Is it worth the trouble to switch? do they come without the ebpv? how much bigger are they? Just a few questions, any thoughts are appreciated. Thanks :dizzy
Fire1
Certified Diesel Driver
They have no wastegate, but do have an EBPV. The exhaust housing is a 1.15 A/R Vs .84 A/R for the superduty. I was gonna out one on, but got tired of looking and went with GTP38R.
bigrigr
Real trks hv 3 pdls
provo, utah
Whats the benefit of no wastegate, wont that create turbo lag? Are they a direct bolt on?
Fire1
A wastegate does nothing for Lag. It is there to bypass exhaust to limit excess boost on the top end. The reason the van turbo does not have one is due to the large exhaust housing. It will limit total boost by nature. Now, the larger housing will in theory make it lag more than your stock one. How much, I do not know.
It will bolt directly on, but you will need an exhaust adapter. I believe Bean's Diesel has them, Diesel Innovations used to, may still.
From what I've heard these are great for towing as they will help lower EGT's and help with surge. Some add the Wicked Wheel and/or the ATS ported compressor housing to help with surge also. Those two mods will also increase the whistle if you like that.
aklim
Hartford, WI USA
With the EBPV removed, it runs a little cooler and some have noticed some lag on it. Of course with the the AC Stage II injectors, that problem is fixed.
