Help Needed Vibration
IDSTROKER
Blackfoot ID
Blackfoot ID
Hello everyone it's Been A while working and Playing. Ok Back to my viberation that i have is. No more viberation at high speeds but i noticed this weekend when pulling my new trailer.Sometime's when i turn a corner left or right with little throttle i get viberaton. not sure if it is back to driveline or rear end. but i sure that it is not coming from the tranny.
Sounds like the Posi Traction unit in the Rear End is not slipping when cornering. This will give you the vibration in the turns. Ford sells a Posi Traction Friction Modifier in like Pint bottles. Add some of this to your rear end oil and you should be good.
Dave :)
IDSTROKER
Blackfoot ID
Blackfoot ID
I don't think it's a posi but i will check it to see i need to change the gear lube anyway thanks for all the help.
