whats this plug, i have one on ea fender well
no-red 6 0
Senioritis
southmetro MN
well with manual hubs, the only line you should not have then would be the vac line....you should at least have the brake line AND abs line.....as i said, i think someone replaced it before you took ownership and either cut it off OR bought a hub w/o abs line/fitting.....i was careful when ordering mine to be sure i got one w/ abs....
hope you get it sorted out AND your tranny issue.
here is my ignorance though: did the 2000 come w/ front abs? i know it was mentioned that it was fitted w/ the line - was/could it have been an option?
I was under the impression that they all had it. However, a quick check of the parts catalog reveals that not to be the case.
Kenbo11
