Wiring up air horns
TexasA&M
Austin, Texas
Howdy everyone -
Just got my air horns from UPS and hoping to get started installing them this weekend. For those of you who have them, who wired them into the factory horn system? Where is the stock horn, and where is the best place to tap into it?
Thanks!!
- Steve
Zmann ARGH
AZ
I did and I just used a fused relay and bypassed the oem horn ,, the factory horn is buried under the passanger side fender ,,
TexasA&M
Austin, Texas
That is an option, but I want the horns to work when using the steering wheel horn button.
Zmann ARGH
AZ
you can actually intercept the wire in a loom near the passenger side battery ,, if you decide to get to the wire from the horn plug ,, If I remember correctly you can pull back the fender splash guard enough to access it
Zmann ARGH
AZ
My whole post was on how to make the new air horns work with the oem horn button
or are you after something I missed ?
Zmann ARGH
AZ
,,,,,,,,,,,, I would have to go look at it to see what color it was
Zmann ARGH
AZ
My air horns use a 12v compressor that runs to power the horn but uses no storage tank ..
so I used a relay ,, the reason for the relay is the amp draw was too much for the horn circuit so I ran the relay it basically allows a small circuit to switch a larger circuit I ran from the battery to the relay to the comp ,, I don't now what your system is ? you may not need a relay at all
TexasA&M
Austin, Texas
I've got a compressor and a tank. I will use a relay to power the compressor.
All I need to know is where the wire is on the factory horn so that I can use it to activate the new air horns. Amp draw will be minimal.
