2000 f350 oil leak!
cylemik
plainfield,il
hi im new to this
but i have a 2000 7.3 with a hypermax turbo i just did the o rings in the pedistal bc i have a massive oil leak now after replaceing i still have a leak coming from the same spott on the back on the engine between the starter and the pan. the valley is dry now after doing the o rings, what should start to check now? it only leaks when the truck is running some times a constant drip and other times just drip. please help me!!:hail
thanks
Cyle
clean the whole thing spotless with engine degreaser.. then add an ultraviolet dye to the oil.. run it for a while then use a black light to chase the leak back to the source..
Guinness
superdudiest
GlenMoore, Pa USA
Sounds like dipstick bung on the oil pan, I just fixed this on mine with rtv by baking the nut off and carefully gooping it around the bung retighten the nut and wipe off excessthere is a more permanent repair if you replace the oring inside the pan but its a lot more difficult,
wilsonbaird
wilsonbaird
Clearwater
Yap, I had also a leak there on mine truck too, and I also locked that big nut.
