just got the reply from comp cams.
After looking through your information I suggest one of our XTREME ENERGY series cams. Here is the part number for the cam I have suggested (35-246-3). I recommend that you change you valve springs and lifters if you are interested we here at Comp Cams can put kits together. Just let me know? I will list the specs on this cam below. If you have any questions feel free to reply or call our tech line. Have a great day.
NOTE: You either will need to use a very mild cam or put this cam on a 112 degree lobe separation angle to increase your vacuum.
INTAKE MASTER 5445
EXHAUST MASTER 5208
ENGINE FW XE274H-10
GRIND NUMBER FW XE274H-10
INT EXH
HYDRAULIC Y/N YES DUR @.050 230 236
INTAKE EXHAUST LOBE LIFT .3270 .3270
VALVE ADJUSTMENT HYD HYD ROCKER RATIO .00 .00
MAX GROSS VALVE LIFT .519 .523
DUR @ .006 TAPPET LIFT 274 286 LOBE SEPARATI 110.0
ADVANCE 4
VALVE TIMING OPEN CLOSE VALVE SPRINGS 986-16
.006 INT 31 63
EXH 77 29
THESE SPECS ARE FOR CAM(S) INSTALLED
106.0 INTAKE CENTERLINE
For more information about any other COMP CAMS product, please feel free to contact COMP CAMS at 1-800-999-0853 or at COMP Cams - Performance Camshafts, Valve Train, & Much More
Thank you for choosing COMP CAMS
COLE VENTRONE, 901-795-2400 Ext 534
Technical Consultant
Competition Cams
INTAKE MASTER 5445
EXHAUST MASTER 5208
ENGINE FW XE274H-10
INT EXH
ADVANCE 4
.006 INT 31 63
EXH 77 29
Competition Cams
