AIH Delete?
whatabudro said:
no it uses a 3/8 square drive from a ratchet.
Okee dokee as I know Tbar got the plug that takes an allen wrench but don't recall where he picked it up at.
bigdaddyTank said:
You can make your own using a 470ohm 1/2 to 1 watt resistor. Add the resistor to a wire and ground it from the post the AIH wire was removed from on the relay, the resistor simulates the AIH.
BigDaddy can you clarify which direction the resistor will go to the solenoid? Gold or Yellow band to it?
Bill :thanks :sweet
whatabudro
Launched
It's done now thanks to Bill for stopping by with resistor already assembled. Nice X by the way. I took a few photos of the resistor install if someone wants to add them to the WIKI since thats a little over my head. Bill I ment to get the part number from you on that upper hose, and I'll let you know when I'm ready for the "shim" help.
http://community.webshots.com/scrip...D=387169736&photoID=397510671&security=BMoMWZ
http://community.webshots.com/scrip...D=387169736&photoID=397511106&security=ulTZzQ
http://community.webshots.com/scrip...D=387169736&photoID=397511459&security=nsprQZ
Glad to lend a hand on the jumper wire for AIH,see if you can round up a length of plastic wire loom covering for the jumper as I didn't have time to pick up another roll ;)
The photo links you posted see if you can logout of your webshots account and re-post the public URL's :sweet
The upper hose number is Gates #22433 or NAPA #9066 for dual alternator setup if they ask.
I have the fuel pressure gauge set aside for you when you're ready to do the fuel pressure bump.
Bill
whatabudro
Launched
Bill
I dont know what you mean about the photos, you can't view them?
thanks for the part numbers
I'll check my stock of -AN fittings and get all my plumbing in stock.
whatabudro
Launched
Bill
try these
http://image64.webshots.com/64/1/6/71/397510671BMoMWZ_ph.jpg
http://image62.webshots.com/162/1/11/6/397511106ulTZzQ_ph.jpg
http://image52.webshots.com/52/1/14/59/397511459nsprQZ_ph.jpg
