BIG Weekend Planned
Its really alot easier than you probably have yourself believing right now. Just go slow, be methodical, and check everything twice. Read the article in the WIKI, PM me this weekend if you get in a bind. I will be around the 'puter most of the weekend and if you need some assistance I could get in touch with you via phone........
KansasDiesel
fly'n low on WVO
Kansas City area
:thanks Stroker,
I have changed o-rings on the left bank injectors before with no problems, but a few more things have to be removed for the other side. That is your write up in the WIKI isn't it? I might just have to clean the cyl's out by cranking it over too :roflmao Sounds like fun.
I will PM you if I get in a bind. :thanks
:cowboy:
KansasDiesel said:
:thanks Stroker,
If youve already been in that far then you'll have no problems doing an injector swap.;)
Yes.:sweet
You havent experienced life until youve done that.:roflmao
:cowboy:
Cool.
sagebel
Stock? Pfft!
Albuquerque, NM
It should be noted that it is better to be the one cranking and not the one under the hood (unless you just use the starter solenoid, then you can expirience both :thumbs )
Scott
KansasDiesel
fly'n low on WVO
Kansas City area
Scott
Oh I will use the starter solenoid, I wouldn't want to miss that experience. :roflmao
gquad41
