Can I flip my rear shackle/spring hangers?
pacman99
Gadsden, Ala
Shackle Reversal?
I'm Confused about this subject, I spend alot of time with off road vehicles, a shackle reversal is where you move the piviot (hard mount) on leaf springs to the oposite end? In the front of a leaf spring vehicle the moving shackle is tword the radiator side of the axel and mounted solid to the frame in the rear, switching these positions is a shacle reversal. Done all the time on off road vehicles, not necessarily to gain hight, but to keep the springs from bending when you encounter an obstacle and try to go over it.
Don
06silvercrew
Morganton, NC
Ok, maybe Im confused on the 'technical" name of what Im doing. But after I described what Im doing I dont see how there can be any confusion to what Im doing?
Sky Mfg makes replacement brackets that are much better you'll find the rear about 1/2 way down the page.
The problem with flipping the rear shackle is that since they were originally engineered for tension and you're now replacing them as compression you need to reinforce them support the extra pressure.
