Help Needed Clutch Problem Cant Move
chamillionaire66
Remember?
Elpaso/Texas
:dunno:cussing: I went offroading last night Got stuck in mud, and now i can't move anywere, when i press the clutch it stays half way down, it use to be hard pressing the peddle down, now its softish. i dont know what else to do. i feel like kicking my truck but what good is that gonna do!
PS: The clutch pedal already stayed half way down, but now its worse. Cuzz i cant shift into gear. I was thinking it needs Fluid in the master cyclinder, but i have no clue were that is!
Frankenstien
Frankestien
South Prairie Wa.
What year is your Truck?...
1 of three things has happened
1: You've bent your Clutch Fork, Most likely if your truck is a 99-2002
2: Your Master/Slave cylinder is shot.
3: You've worn a spot through your pressure plate, not allowing you to engage your clutch.
# 2 is the only one you can fix without removing your tranny...
Your master cyl is on the fire wall drivers side, small round black ... holds about 3 oz.
chamillionaire66
Remember?
Elpaso/Texas
The Year is
1996
chamillionaire66
Remember?
Elpaso/Texas
Bro thank you so much, guess what
i was checking fluids and on the Clutch Master Cylinder
all it needed was fluid, lmfao i feel so dumb!!! now i know what was wrong. lol thanks for your help
02SilverStroke
Collin County, Texas
When I read the first post, my instincts suggested fluid in the clutch master cylinder. Glad to see that's what it was. My son has a 95 F150 5 Speed, and he has had problems with that. Earlier this year, he took our car out of town, and I drove his pickup for a day, and the master cylinder messed up while I was driving it. Sure was hard to shift it. The clutch had very little freedom. Barely start releasing it and it was engaged. Again, glad you got it going again.
