door always open
SMOKNZ
Cleveland, WI
I know this sounds stupid, but I have one door that will not register closed and the door ajar light and dome light stays on. It's night and like 0 outside so I didn't spend to much time trying to diagnose the problem. How do the door pin switches work on these trucks. I couldn't even find them. This is on a 99 F350 with the crew cab.
BBBxcursion
IL
There's a sensor inside the door that is doing this to you. I can't remember the part number, but it's a very common problem. I greased my hinge up when it happened a while ago, never happened since
SMOKNZ
Cleveland, WI
my drivers side door creeks when I open it, I will try a little grease and see if that helps.
Weweld
Fillmore Ca.
On the 99's I sprayed the latches with WD40 and the lights went out.
GENE
Fire1
Certified Diesel Driver
I believe I seen it posted before that the sensor is in the latch are and that lubrication w/ WD40 or such will end this problem.
Hoss 350
My GSP, Dutch
Spokane, WA
Yup, WD-40 worked for me! Going on an year and a half. Don't replace, just juice it up with WD....
I third or fourth the wd-40 method. I sprayed the latches down and have not had any more trouble..
W4RLR
High Tech Hillbilly
Sewanee, TN
WD-40. Grease will tend to attract dirt and gum up the works after a while.
If there is any water or moisture in the switch, WD-40 is the ticket for it.
W ater
D isplacement
formula number 40
It was originally developed for the space program.
I fourth or fifth the WD. Did my doors/latches last week. Speak'n of WD... I bought that new can with the permanent straw thingy !! Slick Deal. No more lost straw thingy. Flip it down and spray from the nozzle !!
It's Lifes Little things that make you :D
I also have one of those new flip-up straw thingy. I have several other old cans so I haven't tried it out yet but it looks like a good deal. I always lose the straw right off..
