I need some help here to see how all of this looks. I know what some of the things are, and others I do not.
My mobile shop ramps
Carrier Bearing Photos
I am pushing up in this picture and was able to push it about an 1/8" up.
Is that normal?
Transfer Case joint
Rear end joint (this doesn't look right, is it leaking?)
Slip Joint connection
What is the best procedure for taking the drive shaft out to service it?
If that play in the carrier bearing is too much and needs replacing, is it just a simple remove the old one and put a new one back in?
Is that normal?
Transfer Case joint
