Fan clutch
mikejones96
Thornton,CO,USA
So the fan clutch on my truck is on its way out i think. I can hear it locking up before i think it should. My question is if anyone out there swapped in an electric fan kit. The clutch is $188 at autozone and I've found fan kits for $200. So i figure if its doable without a massive headache i wanna do it.
save your money
when they die, they don't lock at all
iracemine
black and tan
Cheese Curtain
yeah mine actually came on for the first time in years when I was towing my new rig after I cam to a elongated stop.
Its a hot one out there man!
mikejones96
Thornton,CO,USA
I've seen those but i'ld rather not spend $600 you know. And i know its the fan clutch cause it'll lock up before its heated up and the computer has the right temp i checked it with a good snap on scan tool.
bigrigr
Real trks hv 3 pdls
provo, utah
Your a/c being on can turn on the fan clutch, without the engine getting hotter. Don't forget about the condenser in front of the radiator that is releasing heat also!
Speaking of Condensers ?
Not a bad idea to back flush the Condenser & Radiator with air and water, now and again either. Helps with A/C & Engine temps ?
I blow mine out (from the back side) with 60 psi air, to knock off the Big Chunks.. then run a semi stiff brush up & down the fins*, to loosen the smaller stuff.. then back flush the whole works with water. Radiator too.
One of those hose-end thingys for hosing off driveways & sidewalks works Real good, It's small and puts out a Fan spray pattern.. with a bit of force to it.
:dunno
* a semi stiff brush will also help straighten the fins back out.. from any impacts ?
how in the heck to you get to the back of all of it? seems like the fan/fan housing is in the way and there wouldnt be a whole lot of room to get back in there.
