Help Needed HELP! Early 99 7.3 stalled and won't start...
roozterdvx
Ft. Myers, FL
started the truck up,let it warm up in the driveway for a few mins and nothing out of the ordinary
drove 2 miles to the gas station and put in 15gals of fuel, left the truck idling while pumping fuel, running fine
go to pull out from the station, and the idle dropped and engine stalled
cranks and won't start
called a buddy and towed the truck home
tried starting again and nothing, just turns over, doesn't start
at 1 point it sputtered a little after numerous attempts of starting but won't light off
did some reading and figured I'd start with the CPS, (still have the original OEM 132000 miles)
put a new gray CPS in and still just cranks and won't start
disconnected the batteries for 30mins, cleaned the terminals and reconnected
cranked her over and she lit! oh joy, my baby is fixed!...NOT!
let her warm up a few mins and she starts sputtering then seems like it dropped 4 cyls, (loping really bad)
gave it some throttle and it smoothed out, back to idle and loping bad then died
tried to restart and it lit off but loped for 2 secs, then died
cranked it over again and nothing, just cranks but won't start
I also tried diconnecting the ICP sensor with the same results
I did open the drain on the back of the filter housing and clean fuel came out.
(I used a hose and clear bottle to contain the fuel)
I also turned the key to the on position with the drain opened and it looked like a steady stream of fuel coming out and almost filled a 2 liter bottle in a short time.
This ordeal started 2 days ago.
Today, I changed out the IPR...
...drained the HPOP res with a hand vac pump and refilled with fresh Rotella 15w40 to within 1/2" of the top
Still no start, just cranks and not even a hint of firing up.
Daylight is gone so tomorrow after work, I am goin to pull the valve covers to check the UVCH connections.
any help is appreciated
Maybe the CPS? They have a history of dieing and causing a no start. They are pretty cheap at Ford or IH.
Clean the battery posts & clamps up.. REAL good'n try it again.
roozterdvx
Ft. Myers, FL
did the bat posts and terminals...
cleaned them till the shined
also tried cranking with a battery charger connected
Does the Tach move and is the WTS light lit when you crank it ?
Test & Check all the fuses.. In the cab and under the hood.
roozterdvx
Ft. Myers, FL
will check all fuses tomorrow
WTS light works
tach comes up off the zero when cranking but just barely
is your new CPS a parts store one or a Ford/IH one?
access to a scan tool? Even though the SES light isn't on, there might be codes..
Tbar
SDD STAFF/Moderator
drove 2 miles to the gas station and put in 15gals of fuel, left the truck idling while pumping fuel, running fine go to pull out from the station, and the idle dropped and engine stalled
If it were me I wouldn't over look the obvious........bad/wrong fuel.
Also, all that cranking pulls down the bats. Unlike a car these engines will turn over fine but in the absence of sufficient/correct voltage to the computer they won't start.
Put the battery charger on the truck over night and look into testing a known good fuel source. ie - drop a hose from the pump into a 5 gal can with fuel from a different station. Cycle the pump with the fuel drain open to get the new fuel to the bowl.......then close and try and start.
Tbar
roozterdvx
Ft. Myers, FL
when I get home from work, I'm gonna check all fuses, (under dash and under hood), then pull the valve covers to check the UVCH connections.
I bought a parts store CPS since it was Sat night and no chance to get an OEM
I will charge the batts while working on the other stuff tonight
As far as the fuel, I will have to figure out a way to connect from the frame mounted pump to a can...
I'm hoping a friend of a friend comes thru on the scanner...
