Help me pick a tire....BFG MT KM2, ATKOE, TOYO AT, MICH LTX M/S....others?
Pick new shoes for the fat girl:
  • BFGoodrich MT KM2
    Votes: 1 3.2%
  • BFGoodrich AT KO
    Votes: 14 45.2%
  • Toyo AT
    Votes: 3 9.7%
  • Michelin LTX
    Votes: 6 19.4%
  • Other
    Votes: 7 22.6%
  • Total voters
    31
paulkeith
Da A
so...help me pick a tire. I got something like 20k miles out of the set of mastercraft courser at2s i put on last march, with a lot of chunking to boot. file those away under tires i'll never buy again.
So, I'm sticking with the 285/75 variety, but having trouble deciding if I should go baller with an MT, or keep it sensible and get a 'road' tire. I've narrowed it ( I think) to:
BFGoodrich MT KM2
BFGoodrich AT KO
Toyo AT
Michelin LTX M/S
or...some other suggestions? Price on the Toyo MT is outrageous, otherwise I'd be considering it too.
Has anyone run through a set of KM2s? What kind of mileage are they generating on PSDs?
Thanks,
Paul
I'm getting the BFGoodrich AT KO,It's a hard rubber and should last longer.
i've had 2 sets of the bfg a/t's. got about 40k out of each and really had trouble keeping them balanced. when they start to wear they get pretty loud, the ride gets rough, and it shakes like hell when you hit the brakes.
the michelen ltx m/s is by far a superior tire to all of those, but i went with the goodyear wrangler silent armor just a few months ago. i've got about 5k on them and they have been wonderful! much quieter on the road, smoother ride, and off-road capability looks to be comparable to bfg a/t's. the wet traction is also superior to bfg's as well
BFG's always did an awesome job for me. Out of 3 sets I used on my F350, I averaged close to 50,000 miles per set.
I put Michelin LTX M/S on the wife's Expedition and they ride and perform very well, but I prefer the BFG's on the Superduty
One thing to is get the right load range. The truck comes from the builder with E,F load range. If you put D or less they will burn out sooner because the weight of your truck.
jimmypage
mesa
i have the procomp extreme at's and love them defiantly would by another set
atk
Moderator
simcoe, ontario, canada
i always had good luck with BFG`s AT`s. i also have used the Michelin LTX`s with good results, but i found the BFG`S to be a better tire in the winter....
pete37922
JERZY
i have Cooper STTs...only about 5k miles but luv them so far !!!
paulkeith
Da A
so in that case, given the complete absence of "winter" in georgia....
it gets "cold," by which i mean in the 20s, and rains sometimes.
atk
Moderator
depending on the type of driving you do?....if you do alot of highway driving, probaly the michelins would be the best bet. also, the more aggressive you go, the more tire wear. the BFG`s AT, i find to be a good all round tire and if you go with load range "E", you will get a little better tire wear then with load range "D"....:2c...hope this helps
