Question Oil questions
mygsris2slo4u
Erial/NJ
Got a couple of questions for you guys. Has anyone had any problems in dealing with blackstone labs (probably USPS)? I have sent samples from my last two oil changes and have never gotten a test performed. Not too sure who's fault it is, but I just want to get a test done.
Next question is for guys using full synthetic oils (amsoil specifically). What kind of drain intervals are you getting out of it? Are you getting the oil tested? I ask because I am considering the switch, but with my inability to get the oil tested I don't know if I want to lay out the money for oil that they claim can get 25k+ on a change. Any thoughts on the issue would be appreciated.
straitcountry
Huber Heights, Oh
I use the kit from Amsoil that includes the UPS label. I have not had any trouble getting my results. I run the Amsoil 15W40 Heavy Duty in my truck and the last time I had it tested they said that I still had 45% oil life left. the truck had 10,000 miles on that oil before it was tested. unless you drive alot I am not sure that I would go 25,000 miles unless you have the bypass filter set-up. I change my oil and fuel filter every 10,000 miles or so.
Jay
I have been using Blackstone Labs for many years and haven't had any problems with anything. I use the Post Office to send in the sample. I do use Blackstones shipping containers, a black tube.
Tbar
SDD STAFF/Moderator
I have never had a problem with Blackstone. Call them.
Tbar
RSG
Savoy IL
No problem here except occasionally a postal driver won't take the sample and I have to take it to the Post Office directly. I use the prepaid USPS labels.
mygsris2slo4u
Erial/NJ
Thanks for the responses. I have a feeling that it is not the labs fault but the USPS. I think I am going the make the switch to amsoil. After looking at the prices it will be much cheaper to use the amsoil hd diesel oil and amsoil filter for $110 than the mobil delvac 1300 and motorcraft filter for $75. I had been changing the mobil oil and filter every 5k. Even if the amsoil is only good for 10k its still a better deal.
Any other thoughts on the topic are welcome.
pete37922
JERZY
i use Amsoil 5w-40 oil...do my changes every 10k miles and oil filters every 5k miles !!!
