Can produce approximately 320 liters of oxygen & hydrogen per hour
-320 per hour = 5 1/3 liters per minute of hydro/oxy gas. being produced.
-a 7.3, idling at 500 rpms not producing any boost, is pulling 1825 liters per minute.
-a 7.3 turning 1500 rpms at 0 psi boost is pulling 5475 liters per minute.
-a 7.3 turning 2500 rpms at 14 psi boost is pulling in 18250 liters per minute.
so, the amount of hydro/oxy gas being made ends up being:
.0029% of the air being pulled in at idle
.00097% at 1500rpm/0psi
.00029% at 2500rpm/14psi
these numbers are very rough. i just dont see how this could ever show an increase of mileage worth the $2000 and trouble of having this huge box in your bed. also...it draws 60 amps, you would need an auxillary alternator, and at idle everything would still dim down like your glowplugs were on.
im not saying this ISNT worth it, im just finding it hard to believe.
