JRJ04
Found a little oil in the valley today after I noticed it accumulating on the TC shield housing. I knew it was leakin a little oil, but after losing 3 injectors...I just said to heck with it...if it runs im leavin it alone.
I'm almos certain its either the boots on the turbo that go down into the engine or the hpx line. Im leaning away from the hpx cause the fittings dont seem to be oily or nasty (i tightened them just to make sure) Theres a spot on the bottom part of the driver side where its all yucky and im guessing with making 20lb of boost on a fairly regular basis it has weakened the boots.
My question now...how hard are these to replace? It doesnt look like you need to remove the entire turbo, just the "baby's butt." Theres a lot of "stuff" connected to the lower portion of it. Hard to remove? Any chance of really screwing something up? Seems like a fairly easy job, but wanted check it out with you guys.
