ye ole CPS
J L Dunn
J L Dunn
Kingwood, tx
I found Ford OEM sensor on eBay for $55+; called several places in the Kingwood/Humble, TX area to see what it would cost to replace on my 1999 F250 7.3L Stroke. Ranges from a quote of $188 at Anderson Ford near Cleveland to $700 at Sullivan's Auto in Kingwood. What a range!
My inquiries about this item tells me that it is a 10 minute job with a 10mm socket, and removal of the serpentine belt is not necessary.
Anyone have any experience in changing out said part, and what do you think of the quotes I had received?
Thanks,
J L Dunn
If you have two hands, a screwdriver and a 10mm socket and a ratchet and 10 minutes free time, change it yourself and save the 188-700 dollars.
Did they really say 700? :wow
Tbar
SDD STAFF/Moderator
Way to simple of a repair not to do it yourself..........
I keep a spare in the truck at all times.
Tbar
Wood County Tx
Thanks,
J L Dunn
you cover me a first class round trip ticket and I will bring the tools and two hands
you provide the cps
700 smackers WOW thats alot of psd parts for later.
piece of pie, if I can get my fat tail under the truck and do it, anyone can. :D
MUDWHISTLE
Diesel Lover
oregon
Thanks,
J L Dunn
700$??? Do they even know what the cps is? That would be like 4000$ an hour since it only takes ten mins or less.-mad -mad
Hoss 350
My GSP, Dutch
Spokane, WA
Thanks,
J L Dunn
1.) Unhook electrical (about as difficult as unplugging a lamp from the wall outlet)
2.) Unscrew 10MM bolt and remove.
3.) Pry CPS out of it's hole with screwdriver
4.) Put new CPS into the hole
5.) Re-install 10MM bolt, torque snug, not too tight
6.) Plug back in electrical.
It should take longer to get the tools ready than to actually do the job...
$180 is ridiculous. $700 is beyond comment.
dserge66
