skyhawk1
Just got my pyro and boost gauges today. I want to install them in the morning. Seems like I saw a how-to on this site with pics a while back. Any help would be appreciated. Thanks in advance.
That would be the pre-turbo method. You can also put it in the top of the downpipe right where it exits the turbo. Some guys worry about the tip of the probe breaking off and going through the turbo when mounted pre-turbo. Mounting it pre-turbo does make for a more accurate reading than post turbo. When mounted post turbo you have to keep the egt a little lower due to heat loss through the turbo.95_stroker said:You want the EGT probe in the drivers side manifold just before it hooks to the up-pipe.
Crumm said:Some guys worry about the tip of the probe breaking off and going through the turbo when mounted pre-turbo.
