ITS DEAD!!!!!!!!!!!
94f450sd
certified nutjob
plymouth,ma
ITS DEAD!!!!!!!!!!!needs an engine
yup its
ok well i got the replacement injector today.put it in and fired it up.i moved it outside to let run.while walking back in the shop i noticed antifreeze pissing out of it somewhere.so i walk back and open the hood.its comeing from the radiator cap.truck only ran for about 5 minutes.radiator hose was hard as a rock.so i figured the thermostat was bad so i replaced and after fighting with a broken bolt i get it runnin again only to do the same thing.i let it run long enough to do a CCT on it and now it comes up with cyl 1 contribution/balance fault!! WTF?!!!!!!!! well the injector with the crackednozzle was #1.so now im in the process of pulling the head.it should not be pressureizing the coolant system as fast as it is.only thing i can come up with at the moment is the piece of nozzle was still in the cylinder and somehow cracked the head.cuz while turning over you can hear the starter strain as usual then it woofs out the intake and spins real easy for a second.
-mad -mad -mad -mad -mad :rant :rant :rant :rant
dpantazis
#12
under the cheddar curtain
oh no!
rich-
that is not good. i will make small animal sacrifices tonite with hopes that you troubles will be something eazy and cheap to fix.
dennis
lukecline
Kansas
well with 328k miles on it anything is possible. Hope its not to expensive to fix.
Luke
94f450sd
certified nutjob
plymouth,ma
the truck has 345,000 now but the engine is out of a 97 e350 that had 128,000 miles on it from a bus company
dansk
Granada Hills, Ca.
What a bummer. I'm sure you will get her up and going and fill us all in on what happened. We need to learn together. It's good talking to you again even in this situation.
Dann
94f450sd
certified nutjob
plymouth,ma
welcome dann,glad you came over!hopefully you will notice the cleaner air around here and stay a while :sweet
i definately keep everybody up to date with the problems on my truck,its the superdutydiesel way!!!:thumbs
roosterdiesel
Earl needs B100
Amarillo,TX
Man that sucks. That #1 hole has been a PITA huh.
Get pics of the carnage when torn down.-popcorn
94f450sd
certified nutjob
plymouth,ma
ill sadly have pictures of it unfortunately.i gotta go work on another members truck in the morning then i gotta figure out an oil pressure issue on my buddies 4 car carrier and then back to my truck :(
94f450sd
certified nutjob
plymouth,ma
if it needs an engine it will most likely get scrapped as i dont have the money for another motor
