larger rear fuel tank
Ragdude
Anyone know of a larger tank that would fit in place of the rear stock 18 gal. on a '96 F350, CC, lwb, PSD ? I would love some extra weight on the back end, plus longer cruise distance.
RoReRi
Verona, NC
Someone else that knows more of the specifics will chime in here, but I have heard of using a Bronco tank. I think its like 33 gallons, but I've slept since I read about them soI could be wrong...:dunno
Good luck
RoReRi
Bronco tank is the cheap way to go if you can find a good tank or the expensive way is Transferflow, do a websearch and you'll find their site. Get ready for sticker shock though.
Welcome to SDD too!
4drdually
Wrench Head
Yardley, PA
the bronco tanks are super cheap, like a 100 bucks. Get the sender too so the gauge reads correctly. Check ebay.
Brad B
Winnie, TX
What year model bronco tanks should I look for? Is install a real PIA ?
the bronco tank from a 96 will work wonderfully. You just need one from a fuel injected bronco so you have a return fitting and vents on the tank.
I have only the bronco tank on my truck and want bigger. 50 will fit where the bronco tank does you just have to custom fab the tank yourself.
When you pick up a Bronco tank be sure and get the mounting straps too or you will need to fab up your own..
