Maiden Maintenance Voyage on 6.0
RoyBoy
Diesel Dork
central WI
You need to thoroughly degrease the intercooler pipes and connections with brake cleaner. A connection with any oil on will blow off eventually. I'm not sure about how you are explaining the retaining ring. I know I used them on my old 6.0 with no problems. I'd either check with DieselSite, or post some pictures up :sweet
Roadie
Gainesville VA
Thanks, if you were to describe their use in ur own words, how did you mount the rings. I'll compare to my mounting. I've written dieselsite and awaiting a response.
Roadie
Gainesville VA
Yesterday I got the Amsoil By-Pass filtration unit installed. Today I am thinking about installing the coolant filtration system. As soon as I get the initial "buy" list done, I'll close this thread and work on my next truck projects. For my maiden voyage, I still have a radiator flush to do, transmission flush and new filters, plus new DieselSite Tranny filter install, fuel pressure regulator upgrade, new thermostat plus quickdrain plug for radiator.
W4RLR
High Tech Hillbilly
Sewanee, TN
Since I have to replace, should I stick with the stock Ranchos? I'm only interested in longevity, and at some point might be pulling, but not more than 10,000 lbs.
Those Ranchos are not Ranchos, but Ford shocks with the Rancho name printed on them. Bilsteins are the way to go, but that's just my humble opinion, the Monroes are a good choice as well. Remember batteries not included, YMMV Member FDIC. ;tu
Roadie
Gainesville VA
lil' slow going, but installed the DieselSite Coolant Filtration system yesterday. I'm thinking Imma give it a rest until Spring now. Maybe get the Edge Insight in the next few months. Come spring, I'll do the transmission fluid swap and Dieselsite transmission filter install.
MONSTERPLOW
Cloud Booster 500HP
I 95n.b. 1/10 Keystone State
Roadie , i ordered mine yesterday . with these 60* days i figure why waste them .
what was the degree of difficulty on the coolant bypass install ?
havent been on site in a while , how yall doin ?
