Satelite Radio
Jamie,the U tools should slide in and both "click" at that point place outward pressure on each U toll while pulling the stereo outward. The stereo contacting edges might be sticky from dried coffee,soda,juice,etc and in that case a light shot of windex/glass cleaner around the edges might be enough to break the sticky surfaces loose enough to draw the stereo out.:sweet
Give er a shot and lemme know how it goes.
ForumBlue
CDXX
Southern California
I think I may have the wrong tools. I just looked online at the one at Wally world and the tips look a bit different than the ones I got at Pep Boys. The one from that says Pep Boys is the one I have. It says its for Fords. Am I supposed to have the one from Wal Mart?
Wal Mart
Pep Boys
iracemine
black and tan
Cheese Curtain
my sirius kinda sounds a littil AM ish is this normal?
I live in northern IL and do not have a lot of "open channels" right now its at 88.1. and im using the direct connect option too. all the "s" sounds are alittil distorted to. any tricks or is this norm?? thanks.
88.7 mhz is what I use on mine. You would be a little AMish if you are indeed off channel.
ForumBlue
CDXX
Southern California
I have used the Pep Boys ones and they work on my truck with the stock radio.
Thats wierd. I've tried it on my truck and my Dads truck, both with stock radios, and it doesn't work on either one. I've tried putting pressure to the outside ,inside,top, and bottom and all it does is just slip right back out.
I can't push them in any further either. I'm going to make a stop at Wal Mart and see if theirs does any better.
Push them in until they just "click" into the taps. Any further won't help. I don't think it is a tool problem, maybe an operator error???
ForumBlue
CDXX
Southern California
Well, I got the ones from Wal Mart and they worked like a charm that sucker slid out so easy I almost dropped it. Sat is in and crystal clear now. Lovin it. Thanks for all the responses guys.:sweet
Pics will be up soon.
NASCAR Mike
Richmond VA
I had problems removing my radio so I removed the slide in cup holder and stuck my hand through to the back of the radio.
It was a tight squeeze but I was able to manage. I keep my XM radio on a normal radio station so when I lose the signal or shut the unit off I still hear music and not static.
ForumBlue
CDXX
Southern California
Good Idea Mike. I just assumed there would be some bleed through on a broadcasting channel, but I'll have to give it a try.
